free website stats program Erratic Oil Gauge | Harley Davidson Forums
Erratic Oil Gauge
90FXRS
Junior Member
Contributor
2001 Twin Cam B. Had a collapsed lifter. After a lifter replacement the oil pressure gauge is not acting the same as before. Use to top out at 60psi or so when it was cold no matter how much rpm. I'm assuming it bypasses some how. Idled at 25 when warm. 52 when riding and warm. Now when it's cold, when you blip the throttle, it will swing to 70 or so. Doesn't do it all the time. When it's warm, idle pressure is lower than before. Riding pressure is around 40 or so.
Bike has a new set of Wood Alpha Series lifters and existing gear-driven cams. Adjusted 4 turns with 32tpi pushrods. Ran a couple of hundred miles, readjusted. Fueling cam support and oil pump.
Thanks up front.
Sounds like the gauge is not reading correctly. My engine is modified and my oil pressure at idle with a warmed up engine is about 8-10 psi and at cruising speeds it climbs to 32-34 which I think is normal.
You may want to try an alternative mechanical gauge and compare readings.
Like Jeff suggests, hook up a known good gauge and see what happens. Is the oil pump/cam plate new? That plate and pump will certainly produce a much different pressure than stock. Could be the bypass valve is sticking but I would go with known good gauge for proof first...
Everything is the same as before except the lifters. The one that collapsed looked to be intact, cup was seated squarely and the clip was intact. New gauge is coming, only other one I have is 50psi max.
I agree with what Bodeen said above. Get an accurate gauge and see what the pressure is. If the external gauge reads more consistently at different RPMs, and shows any pressure around 10psi at idle (hot), and not too high on high RPM (hot), then I would suspect the sending unit or the gauge on the dash. Sending unit is a bit easier to change (especially with the tool) than the dash gauge.
If the external gauge shows inconsistent pressure, then I would suspect the plunger in the plate is hanging up on debris in the port. Not too big a job to remove the plunger, clean it, and swab out the port (especially with a barrel mop). Just have to remove the cam chain spring tensioner to get the plunger out. If the plunger doesn't drop out when the tensioner spring "tail" is out of the way and the plunger spring is removed, use a popsicle stick stuck up into the plunger to snag it.
Let us know what you find.
Cheers,
Yeah, and when I said gauge. I was referring to a test type gauge. Not something that mounts to the bike.....
I've been meaning to get back to this but things have been rather busy here. I finally got in touch with a friend that I thought might have a test gauge. He did. Cold start is a steady 55psi, goes to a little over 60 when you blip the throttle and then, I'm assuming, the bypass kicks in. As it got hotter, the gauge started dropping a little at idle. Rev it up to a steady rpm and she holds at 55psi. After it hot, 205 on the oil temp, it idles at 23psi. So I changed the "worry" gauge and all is well.
Thanks for all of the input. I was suspecting the bypass plunger but I've never dealt with one. Glad it was just the gauge because I was not really looking to get into the camchest.
