free website stats program Engine vibration under load | Harley Davidson Forums
Hoodlum
Hi I have a 2013 103 heratage the rear pipe popped off the barrel a while back I ran it for a few miles while it was like that. I have started to get a vibration from the engine under load. Once I’m cruising at 3000 rpm it smooth. I’m looking at the rear air sensor. Any ideas.
Possibly threw a code when pipe was off. Maybe check for codes and clear them. I know there is a way but I don’t know it. Someone on here probably does!
To read the faultcode's push the reset-button of the odometer, hold it and turn the mainswitch.
All lights on the dash will light up ,and the speedo will make a full sweep.
Now your'e in the Diagnose -mode .
Read this file , that explains it further. Good Luck
  • HarleyDiagCodes.pdf
Yeah done all that. With codes. Replaced crank sensor. As well.
Cheers mate
