I have a 2003 Electra Glide Classic Screaming Eagle 103 including fuel injection.
Occasionally, when the engine is HOT and when I am coming to a stop and roll back the throttle to idle and engage the clutch, the engine RPM goes to zero and the engine quits .. if I try to immediately make a normal start, the engine will not start unless I crack the throttle ..... I have replaced the Engine temp sensor ... the speedometer continues to operate when this happens .... that is, it doesn't go immediately to zero ...?? ten minute cool down and it starts normally ..
