sincityharley
I'm doing a top end rebuild on a 2002 Heritage Softail EFI. I was following the manual line by line. During the rebuild while installing the rocker assembly I followed the directions to find TDC by rotating the wheel while we had a finger on the spark plug hole. We stopped rotating as soon as the air flow through the hole stopped right before it started sucking in. As we started installing the rocker assembly it didn't lay completely flat. We had to ratchet down the rocker assembly and we could feel tension as the rocker assembly was becoming flush. The manual stated that the push rods should spin freely. They weren't able to spin at all. After we torqued it down and rotated the wheel a full revolution back to TDC the push rods would spin freely. Obviously we ran the risk of potentially bending the push rods. The fact that we were able to rotate the tire and get everything at rest to where we could spin the rods, I'm wondering where I went wrong. The piston was most definitely at TDC. We were able to shine a light through the spark plug hole and verify. Ive finished the first cylinder and will be starting on the second in the coming week. Id like to have the second one come together correctly. Any advice would be greatly appreciated.
