Engine Modifications
Discussion in 'Harley Davidson Extreme Modification' started by tcharles, Aug 19, 2010.
  1. tcharles
    tcharles New Member
    3
    I have a 2007 softail std. I have big sucker air cleaner Bossoni pro pipes power commander and Andrews 37h cams. What do you suggest next?
  2. TQuentin1
    4,737
    142
    What are you looking for? Muscle? Show? Go? Need to frame this question in terms of what is important to you.
  3. Hoople
    Hoople Account Removed
    7,198
    34
    For me it would be Riding it.
  4. tcharles
    tcharles New Member
    3
    Muscle
  5. Hoople
    7,198
    34
    Head work. Your spark advance curve is still stock? Much more and you should tig the crank pin.
  6. TQuentin1
    4,737
    142
    OK. Bore kit. Flowed heads. Muscle cams. SERT. Dyno tune.
    As Hoople said above, while you are doing the big bore kit, split the case and have the crank trued, pin welded, and re-trued. More muscle will very likely scissor the stock crank.
    Now once you price all that out, you may be better off getting a large displacement S&S engine ready to go and just mount that in.
