free website stats program engine light | Harley Davidson Forums
engine light
texaspops
I recently installed V&H big radius pipes, Screaming Eagle air cleaner, and a V&H fuel pak on my 2007 Superglide. She is running great but after she warms up the check engine light comes on and stays on. I have checked for codes but there are none ,just the engine light. Any ideas on this problem?
You may have pinched a wire or the like when doing your upgrade. Inspect areas you were doing your mods, especially around the fuel pak and pipes. Also check the oil pressure sensor wiring etc. Odd that you do not have codes...
don't forget to make sure you have the kill switch in the run position when your checking your codes.
Yea that was my problem. I pulled the codes last night and this is what I came up with.
P--P1054
S--none
SP--none
T--no r sp
Are you sure it's not P0154? I didn't see a 1054 on the list.....Gonna have to get the manual and look.
