engine light/rough running
Discussion in 'Electrical' started by uscggmdv2, Sep 2, 2008.
  1. uscggmdv2
    uscggmdv2 New Member
    My engine klight goes on and runns rough and the speed-o dorps to "0". Sputters and bucks. 2004 sportster 1200c. Any answers, ? Thanks, Al
    50
  3. uscggmdv2
    Thannks!!!!!! I see "GLIDER" is the quick responder to alot of problems I appreciate your help and thank you!!!! Will let you know whne I do the codes. Got to get some ink for the printer so I do it step by step with the directions on hand at the bike. Thanks again..... AL
    Will checked and rechecked all codes and finally understoof "NONE" to P/N# and cleared. Went back and checked battery cables and all was tight on TOP and the ground felt funny! Not solid.,,,,,,,,,,THARRR it was hanging by a stran or two down at the engine grounding bolt.........ZaaaZamm.
    Thanks for all the help Glider you gave me more insight to my sporty and understanding it more in todays electronics. Pushed me alittle further to investigate. By the way I'm in North Canaan, CT. Safe riding ALL!!!!! Al
  4. glider
    50
    Those cables are the biggest source of problems. Glad you got a handle on it.
