I have a 2007 ultra classic and whenever the outside temperature gets above 80 degrees. The right turn signal will not work. I suspect the turn signal security module but not sure.
I will try that but will have to wait for it to be hotter then 95 degrees because below that if I shut it off and start it up again it will work for a little bit then quits again.
