riverman
Hi All
I have a 2010 FXDC with 5500 miles on the clock.
3 times now over the last few months when I have hit the start button,nothing.....dead!!!
So I go through the normal check list,run switch on,neutral light on,then I turn the ignition off and back on....still nothing!!
I go through this procedure 4 or 5 times with no luck??
Now I'm not sure why I tried this,I just did!! I pulled the clutch lever in and hit the start button and she fired right up????
So this has happend 3 times now,each time the bike is in neutral and the neutral light on the dash is on,I always double check these first..
So the bike seems to think it's in gear when it's not??...
The only thing I can think of is the neutral switch is faulty....but the neutral light on the dash is lit as it should be so i'm a little puzzled???
I'm not that worried about this,I just do'nt like having any gremlins in the electrical system!!..
So if any of the electrical guru's here have any ideas on what could be causing this I would be interested to hear them......THANK YOU...
WAZ from AUS!!
WAZ from AUS!!
