2006 Electra Glide Classic w/EFI, 32k miles. I was out riding about 230 miles stopped for lunch about 11/2-2 hours came out and would not start just cranked over. Parked on a slight incline outside temp about 90. Up righted bike turned ignition off to reset tip sensor. No go. Just filled up with fuel before stopping.
Got it home and went through the codes check and found none. Checked ignition for fire at plugs-good. Disconnected fuel line at quick disconnect at tank pushed the check valve with screw driver, there was pressure w/gas reconnected line and the (EDITED) started up.
I know Evo's with CV carbs this my first w/ EFI. I bought this bike used with 30K on the clock I've put 2K so far, don't know the past maintenance.
Any ideas on what happened? or maintenance to be done?
Thanks, Duke
Please read this...
Thanks, Duke
Please read this...
