hogrotten Junior Member Dec 22, 2009 #1 okay i read the post and i understand about conecting the vacuum pump to the schrader valve, but the newer models do not have air forks so where do you hook the pump on the newer models? Anyone?:small3d029:
Bud White Well-Known Member Retired Moderators Dec 22, 2009 #2 look at the bottom of your forks for drain plugs.. it explaines that in the easy guide just read farther
Bud White Well-Known Member Retired Moderators Dec 22, 2009 #4 also i did a write up on doing it and instead fo hollowing a bolt i used a metric caliper bleeder screw Front Fork Oil Change - Harley Davidson Community
Bud White Well-Known Member Retired Moderators Dec 24, 2009 #6 yes i did Touring Air Shock Oil Change - Harley Davidson Community
