free website stats program Dyno At Biketoberfest | Harley Davidson Forums
Daveg09
Just thought I'd let ya know how the '09 1200C did on the dyno. Bike is stock except for the stock exhaust being drilled out with an 1 1/4" hole saw. Got 71+ H.P. and 73+ Lbs. of torque. Fuel Air ratios were good. Guess you can't ask for more than that from an almost stock bike. Had a blast tons of stuff to do and goodies to look at. Later guys.
Those are just a few points higher than stock numbers. JMO but you could see better numbers if you opened the air flow with a free flowing AC and some type of fueler. Your bike is probably running a little lean due to the factory settings and opening the exhaust.
