Dyna beads/ride on in auto tires
Discussion in 'General OFF TOPIC' started by Dan.1977P, Aug 13, 2015.
  1. Dan.1977P
    Dan.1977P Active Member
    287
    38
    5
    Anyone use autobalancers in their cars? I'm at the dealer getting a grand Cherokee balanced and aligned and wondered why I can't use the stuff in the jeep too.
    [​IMG]
  2. Jeff Klarich
    4,806
    103
    487
    They can be used in any tubeless tire.
  3. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Dyna Beads got their start as truck tire balancers. But there might be a problem if they are used with air pressure indicators?
  4. Jack Klarich
    FAQ
    This should answer your questions, Pete has a valid point:D
  5. Jeff Klarich
    4,806
    103
    487
    They can be used in tubes as well. My first post was referring to your question about your Jeep which I assume is tubeless.
  6. dolt
    dolt Senior Member
    2,172
    103
    334
  7. Dan.1977P
    287
    38
    5
    I wish I had known the sealants had gotten less messy before I had my last set of tires put on. I'm still thinking of breaking the bead and vacuuming the beads out and replacing with ride on the next time I'm doing service.
    Seems, though, that it doesn't balance auto tires as well as motorcycle tires. Their site says you should dynamically balance first and then add the product.
  8. dolt
    dolt Senior Member
    2,172
    103
    334
    Makes sense, more tire balance. I would spin balance auto tires anyway before applying Ride On; just seems the smart thing to do.
