Door seal question
Discussion in 'General Harley Davidson Topic' started by Trek, Dec 14, 2009.
  1. Trek
    Trek Junior Member
    575
    Has anyone ever heard of putting vaseline on the door seals of your car to keep them from freezing shut in the winter? If you have tried it is there any ill effects to the rubber?
  2. NEWHD74FAN
    8,191
    98
    19
    Vaseline is a petroleum product, so if your door seals are rubber based it can soften and make them turn "mushy" with prolonged use, may want to ask an auto detailer what they use. I do know that Armor All evaporates, and have used STP Son of a Gun which is similar, but has UV blockers which returns them to black and new looking without attracting water.
  3. The4opps1
    The4opps1 Junior Member
    646
    3
    I have used Wd-40 a few times with some measure of success. I have a truck that sits outside all year long, and I found that when we have a wet winter, sometimes the door can stick to the weatherstripping. The WD-40 does a good job of removing the moisture, and hasn't seemed to do much damage, if any at all, to the rubber seals.
  4. joel
    joel Senior Member
    1,026
    128
    I 2nd WD-40 works good, may want to apply it a couple times to allow good coverage. The vaseline will collect dirt, that turns to a slim that will end up on your hands and cloths, it will soften the seal after while and swell it also.
  5. nogoslim
    nogoslim Active Member
    128
    Silicone spray is the best way to go....
  6. 2000classic
    2000classic Active Member
    301
    Spray it on a rag and then wipe it onto the seals. Work great!:D
  7. jock.p
    jock.p Member
    63
    Agreed,Silicone spray is great,spray it on your cables,brake hoses etc.it makes them look like new.Also a light layer on your chrome or polished ally keeps the damp out.
  8. Trek
    Trek Junior Member
    575
    Thanks everyone.
