ThunderRogue
Trying to find out something about clutch adjustment. I've done this for years but just recently noticed this when adjusting the clutch on my '04 Twin Cam with a Energy One Extra Plate kit. A little history, I've always had to only back out the adjuster screw about 1/8 turn and I'm told this is normal for this setup.
So here's what I noticed, I always loosen the cable all the way, then back off the lock nut on the clutch adjuster. I then back out the adjuster screw a few turns to clear the threads and then turn it in until contact. And then I go another half turn just to make sure the pressure plate lifts and everything is touching. (Squeezes the fluid out) Then I back it out again and go in to make contact and then back out 1/8 turn. Pretty much by the book for decades right? Well I noticed if the screw makes contact say at the 2 o'clock position and I back it out and go in again it's now further! It'll go to the 3 o'clock position and if I do it again the 4 o'clock position and so on. Never paid attention to it before but it just doesn't seem right to me! What can be moving? Any thoughts?
