Do you oil a new Arlen Ness air filter
Discussion in 'Engine, Fuel and Exhaust' started by Carroll B, Jul 7, 2010.
  1. Carroll B
    Carroll B Member
    88
    Just installed a big sucker stage 1 filter assembly on my Ultra. Ness sells a re-charge kit and yet the new filter was dry. Do I need to oil the new filter? I have a re-charge kit for my K&N from the filter in my vette and will use this oil if necessary.
  2. kemo
    kemo R.I.P
    1,690
    5
    My Big Sucker came preoiled, so if yours is dry I would oil it if stated in the instruction sheet
    kemo
  3. Bud White
    3,270
    the filter didnt come red or did you order the stainless one
  4. whatyardwork
    whatyardwork Banned
    829
    4
    The filter is white.Its the oil that gives it its color.I now simply use the K&N cleaner and oil as its more readily available.Its virtualy the same filter as the K&N.
    If your filter is white, you need to oil it per the instructions.If it has a red tint to it, its good to go.
  5. Bud White
    3,270
    not true if its the new stainless filter it uses a clear oil
  6. whatyardwork
    whatyardwork Banned
    829
    4
    Thanks Bud, every time I come on this sight I learn something new.
  7. Bud White
    3,270
    not a prob i think you can use either oil but it comes oiled with Clear
  8. glider
    50
    From the Ness installation instructions for the big sucker...
    STEP 6: Fully clean and install your existing air cleaner
    cover as per the specifications in the appropriate service
    manual for your year and model of motorcycle. To ensure
    maximum performance, adopt cleaning and re-oiling of the
    air cleaner element as part of your regular maintenance
    schedule.
  9. NEWHD74FAN
    8,191
    98
    19
    Learn something everyday, I always thought the element was "pink", and just so happened that the oil was reddish in color. Always good to know about the new stainless K&N...
  10. Carroll B
    Carroll B Member
    88
    The filter was red when it came out of the box but it felt dry like it had never been oiled. I will lightly oil it tonight with the oil from my K&N kit.
