TRAINMAN1016
I bought my 06 softail used in 08.It came with stage 1 filter and duel v/h pipes on it.I get a lot of popping let off.I've got it at the dealer now for problem code i beleave it was p6052 low voltage to the efi.I told the service writer that i do not think it is getting very good mpg's and to check to see if any thing was wrong while they had it there..He said that it might not have the upgrade program for the stage one filter and pipes and is running to lean,and if the were to install the program it would be $285.He said he would have it checked.then he talked to me about having the HD tuner installed and dyno done $450 for parts and $285 for the dyno..Is the tuner worth it to get what i need out of the motor? or may be have the stage one program installed?Thanks for any help on this..
