Posted by Rhoades...
There are other posts on this topic on the Internet but I thought I would share my experiences so far.
There are two solutions if you want to add a headset and microphone to your Ultra.
1. Pay HD $199 / set
2. Build your own = $14.00 / set
As an electronics engineer i chose #2
Which includes:
A. logitech PC headset 880 from amazon.com for $12.99 equipped with a short noise canceling boom microphone on the left head phone.
B. (1) male 7 pin DIN connector from your local electronics store for $1.49.
C. Solder DIN connector on to end of cable per pinout below:
Pin 6 unused
Pin 1 = Mic + = Gold colored multistrand wire wound around red shielded wire
Pin 4 = Mic common = Red shielded wire wound with Gold wire used for pin 1
Pin 2 = Headset common = Dark Green
Pin 5 = Left + = Dark Purple
Pin 3 = Right + = Red
Pin 7 = PTT= not used with this headset (use PTT already on bike)
I cannot take credit for finding the wiring diagrams but I did verify the pin out for use with the logitech headset.
Strip the shielding off the red shielded wire. "tin" the wire with solder. All other wires have a very thin plastic coating. Carefully "tin" the end with a fully heated soldering iron and use a small amount of solder. Hold the soldering iron on the end until the solder sticks. This melts the coating off and takes a steady hand and a little patience. Carefully trim the soldered wire to just a few millimeters of soldered wire (prevents shorting when the connector is completed).
Carefully "tin" each of the DIN connector pins (too much heat will melt the plastic around the pins).
Carefully heat each tinned pin and simultaneously insert the tinned wire into the matching pin.
I recommend testing the connector at this point. Plug the bare connector (no shielding or outer rubber cover) into the bikes female DIN connector. Turn the ignition switch to accessory and check the head phones for audio (console audio switch all the way forward). Check the mic ckt by keying the PTT and talk into the boom mic you should hear your voice in your headphones. Once you have successfully verified all functionality apply a large blob of silicone to back of the connector to hold the wires in place (also keeps water out). Finish assembly of the connector shielding and plastic cover. You are now done.
For helmets equipped with pockets for head phones you can carefully cut off the hard plastic piece that connects the two headphones. Insert a headphone into each pocket and carefully route the wire connecting the two headphones inside the helmet behind the padding.
I have tested the headphone for functionality but I have not verified the microphones ability to canel road noise with a road test yet.
Enjoy!!!!
Which includes:
Pin 6 unused
Enjoy!!!!
