DIY Auxiliary Fuel Tank
Discussion in 'General Harley Davidson Topic' started by Maustarman, Oct 22, 2013.
  1. Maustarman
    Maustarman Active Member
    131
    Ok...I've been thinking on getting and Aux fuel tank for a long while now ...You know, all those times when you work in your bike's carbs etc ----you have to take down the tank and mount it back again to test and down again to re-adjust ?
    Here is a simple and cheap solution ...less than $10 compared with the buying alternative of $65 plus.
    I made a short video for reference
    DIY- Motorcycle Auxiliary Fuel Tank - YouTube
    Here is the list of parts you will need:
    1- 5/16" Hose ID, 1/4" NPT Male Barb Hose/Tubing Fitting Connector
    1- 5/16” Hose Adapter/Coupler
    1- 1/4 NPT Brass Fitting, Coupler Male
    1- 1/4" NPT Female Brass Mini Ball inline Valve,
    3- Feet of 5/16 clear hose
    1- Aluminum water bottle
  2. fin_676
    5,778
    153
    285
    That is a good supplementary tool
  3. Maustarman
    131
    Thanks Brian
    Yes, really helpful.
