Difference between SE Air Cleaner Kits for EVO carb vs. TC88 carb
Discussion in 'Engine, Fuel and Exhaust' started by airboatphil, Sep 13, 2008.
  1. airboatphil
    airboatphil New Member
    4
    Could it be that the only difference between SE air cleaner kits for the carb 90+EVO & TC88 is the stick on trim for the outer cover ? The aftermarket air cleaner upgrades cover both models of the carb versions ? I',m just tryin' to get a great deal on ebay, etc.
    Phil
    50
    Different throttle body sizes and spacing on the mount bolts. Also venting is done differently too.
  3. airboatphil
    4
    Is the air horn bolt spacing different ? Is the breather bolt spacing different ? The Arlen kit for those years covers Late EVO carb and early TC88 carb ?
    Phil
  4. glider
    50
    If memory serves me correctly, it's a different mounting between the two. One uses a bracket that runs between the heads and the other bolts directly to the head through the breathers.
