Derby cover ?
Discussion in 'Sportster Models' started by Mueller, Dec 31, 2009.
  1. Mueller
    Mueller Member
    Looking through the HD catalog I thought the "Flame" derby cover would look nice on my bike. Question is; what happens when I take the present derby cover off...does oil spill out, are there gaskets etc? Or is it a job left up to the dealer?
    Thanks
    Mueller
  2. Hoople
    Hoople Account Removed
    7,198
    34
    It does not on my 09 Dyna. Even with the bike leaning on the jiffy stand to the left, no oil comes out.:p
    The cover on mine has a captive silicone O ring. No big deal. Go for it!
  3. Hoople
    7,198
    34
    Smitty, your right,, it really is flat. It almost looks more like a "belt". But when in place, it stands on edge. Is
    that the way it is on a Sportster?
  4. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Mueller; this is one of the easier engine/accessory updates you can accomplish & it's a fairly simple process. If you're concerned on fluid's, put a small block under your stand to level the bike. From there it's pretty much wrenching off the old cover & installing the new one. Couple of cautions - (1). make sure you have the correct bit for your derby cover bolts. (2). Like smitty ID'd - get the new gasket. (3). Follow instructions for bolt tightening & torque specs. Finally, sit back & smile w/your new bike "bling, bling."
  5. Ozark340
    Ozark340 New Member
    I just replaced the one on my '08 this summer. If the bike is fairly upright nothing should leak out. Use a couple small dabs of grease or silicone to hold the gasket in place while installing the new cover. It's a bear to keep it in the groove otherwise.
  6. fwcole
    fwcole Active Member
    189
    If your mechanically inclined enough to ride it that job shouldnt be a problem, dont be scared its only chrome it wont bite. Good luck and enjoy!
  7. walleye
    walleye Junior Member Contributor
    944
    3
    Why not get a personalized derby cover so it is not like all the rest? Here is mine, The Black Pearl.
  8. Mueller
    Mueller Member
    Walleye that is a neat idea...where do you get the personalized cover?
    Mueller
  9. NEWHD74FAN
    8,191
    98
    19
    Walleye...YAR Mate-tee, interesting twist adding custom derby cover...there was a post from Smitty I think about engravers who even put military logos and stuff on them and fuel covers.
    Regarding install, Iceman has you covered, leveling the bike (I leaned bike against wall and put stack of boards under the bike to steady) or bungee strategically to bike hooks on wall. Just make sure your tools fit the fasteners and you may even want to replace them, as they are usually "inexpensive" cadmium plated ones that oxidize or corrode with age...with some decent stainless or chromium ones with threadsealer.
  10. Hooligan
    Hooligan Member
    45
    all the ones i have done, the oil will come out of the bike on the side stand, easy fix is just stand it upright, torque is 100 INCH POUNDS
