Dead in the water
Discussion in 'Sportster Models' started by dave101, Jul 5, 2009.
  1. dave101
    dave101 New Member
    4
    I have screaming eagle 1200 sportster. I went to start it yesterday and it turned over good three times. I stopped to double check pitcock and tried again. It did nothing. No lights, horn, starter, nothing. Checked main fuse and voltage to starter solenoid, ok. Ground cable tight on both ends. It's like not having a battery connected but battery checks 12.8 volts.
    Any help accepted, miss my ride.
    Dave101
    50
    Never heard of a SE sportster, must be a rare one :s
    Remove the battery cables from the battery, clean them and reinstall them. Also check the other ends of the cables too.
  3. HarleyHarry
    HarleyHarry Banned
    548
    Hi Dave welcome to the forum.
    Have you checked the working of your "run" switch yet?
  4. dave101
    dave101 New Member
    4
    Tried run switch,engine doesn't turn over and hear no click. no headlights,oil light,turn signal or horn. nothing. voltage reads to starter post. checked ground.
  5. hjacobson1
    hjacobson1 Active Member
    107
    Hi Dave;
    Welcome to the forum.
    A little more information would help such as the year of the bike and what modifications have been done.
    Did you make any modifications just prior to this problem? Have any issues before that might be related?
    Jake
  6. dave101
    dave101 New Member
    4
    It's a 2002 1200 sportster. No modifications since owned. It turned over 3 times before I stopped to double check pitcock.Tried starting again, wouldn't turn over.Noticed indicator lights out. Tried turn signals and horn, nothing. Checked key switch to make sure its on,was on. Checked battery,12.8 volts. Main fuse reads continuity. Voltage down to starter,12.8. Its been cover for about 2 weeks since last ride. First thing I checked was kill switch. Tried shifting gears still no neutral light or horn. It's like the battery is total dead.
  7. jloomis19
    jloomis19 Active Member
    131
    Id say turn everything on, and try a rolling jump start...Works in cars, so my guess is it could possibly work to at least get it started.
  8. hjacobson1
    107
    Hi Dave;
    Assuming you cleaned the battery terminals as Glider suggested, go back to the fuse and check across the terminals that the fuse plugs into for voltage. This should read the same as the battery. If there is corrosion on the sockets that the main fuse goes into, this may be your problem.
    If this proves to be ok, then move up the circuit to the key switch. With the key on, you should have 12 volts coming out of the switch, if not.. you may have the culprit.
    Also remove the battery and take to a battery shop and have it checked. It's very possible to show 12 volts and have no starting power at all.
    Good luck
    Jake
  9. 1200Pilot
    1200Pilot New Member
    3
    That 12 volt battery should have about 13.5 volts on the meter to be in good condition.
  10. bikermoses
    bikermoses Banned
    144
    Battery is junk sorry man and good luck.Have you tested the draw on battery bet it dont stay at 12 volts:s
