Fisherking
I just got a Dark horse crank4 inch with 3500 miles on it . It has been ballanced crank pin welded trued and some weight taken off. I got this from a vender on another forum as he said he just through one out. I almost fell off my stool. He said he could go grab it and if I had an adress in the U.S.A. he would ship it to me at caust.. I jumped all over it.
My question is, I have done a 95 build Static comp at about 9.8 and 9.2 corrected 185 psi at 750 feet .
I'm running Andrews 57 cams . Intake raised 3/8 of an inch ported with 1.9 intake and 1.585 exh.
I'm planing on getting another set of engine casses and put the new crank in that . with my build would you put the Timken angeled bearing kit in the the crank cases or just leave them as they are ?
Thanks F.K.
Thanks F.K.
