custom made RJS Originals Heat Heflectors
Discussion in 'Softail Models' started by zoood, May 29, 2011.
  1. zoood
    zoood Junior Member Product Contributor
    663
    5
    I had been requested to make custom heat deflectors to match this individuals softail. I will be offering this to others. But this will have to be as a winter project.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    zoood
  2. Jack Klarich
    Another fine product, you sure have TALENT:s
  3. glider
    50
    A man of many talents. Nice work! :D
  4. zoood
    663
    5
    Thank you all for that. The rubber "U" channel. I can only get that in black. When I airbrushed. I used createx water base acrylic paints. Since the paint drys as a flexible plastic finish. I was able to match the color swatch he provided and when I shaped the deflectors. The paint didnt crack! Worked out perfect! I had to hand paint the rubber. Had to flow it on so there would be no brush strokes. Turned out pretty darn good too.
    zoood
  5. HDDon
    5,562
    133
    236
    Zoood get ready for an increase in business. This is one of the best jobs I have seen and the color match is incredible. If this gets out to the public you may have to start hiring. Don
  6. zoood
    663
    5
    I only hand-painted the edging ( rubber "U" Channel ) to the color of the piping he has as trim on the rest. He had the seat covered in that brown vinyl. He also enough to send me so I could cover the deflectors with that.
    But it does look sweet!
    zoood
