propflux01
Hello,
Got a problem with the CC on my '03 Ultra. Had been working just fine until my last two rides. the "C" comes up when I try to set it, but doesn't hold. I pulled the codes on it and 213, lots of 122 and 113. Most of these seem fairly normal reasons for the CC to be disengaged. Brake lights work perfect, even when trying to shake the levers. Tried the CC reset and didn't change anything. I have not done anything handlebar-wise or anything else for that matter maintenance-wise. Puling wire off of throttle cable made no difference in operation or testing.
I am stumped on where to check next.:dknow
Also, all other electronics work, speedo, tach, etc. No check engine light has or is illuminated
