free website stats program cracked engine case | Harley Davidson Forums
cracked engine case
doug70767
I was trying to completley drain the oil out of my bike at my first oil change to get all the factory oil out of it. While doing this I broke the bottom corner off next to the drain plug. I have tried JB Weld and several other two part epoxies. After the first repair I noticed a small leak so that is when I started over and nothing is working. Is there anything I can try or do I just need to bite the bullet and buy a new case?
If you are referring to the allen head plug under the engine in the case, I would bite the bullet and replace it but don't make the mistake again.
We just had a post yesterday about the same thing and I advise against removal of that plug. It isn't there to facilitate removal of oil from the engine.
Possible if you find a good welder, he may be able to help you out.
Check the self help area before attempting services for any tips.
Proper Oil Changing Info - Harley Davidson Community
Oil pans are not to spendy, repairing them HMMMMM cleaning aluminum for welding not fun
Thanks. I will not make the mistake again.
Do you know where I can get a replacement case cheaper than through the dealer?
