Hi, On 2010 FatBoy, have most or all problems reguarding the counterbalance chains and bearings been fixed on the new TC96 engines?
Thanks In Advance
wilks3
Thanks In Advance
wilks3
The counterbalance chains really aren't much of a problem unless you drop a gear too many and dump the clutch hard. This could spin the drive sprocket for the chains on the shaft and put the balancers into an unbalanced state.
I believe you may be referring to the cam chain in the twin cam. It's been upgraded to a hydraulic unit now that is far superior to the older setup with the tensioner pads that wear out prematurely.
Thanks Glider, I had read about the bad bearings or the chains eating tensioners and was hoping that had been upgraded. I guess hyd unit really helped it a bunch.
wilks3
