Richard1029
I have a 2005 heritage from the beginning it's coughed when it is cold but now it's getting worse. HD mech. re-jeted the carb and installed a high flow air filter. anyone have the same and what did you do to fix the issue.
I do pull out the enricher knob when it's cold but it starts making its way back in about five or seven miles out. some mornings it will still cough even though I have the enricher out. Would it help if I increase the Idle just a bit? or how do you know if the MAP sensor is working? From what I read in the manual it's critical for the engine to run correctly.
Rich
