Compensator Replacement
Discussion in 'Transmission' started by odin2207, Jul 7, 2010.
  1. odin2207
    odin2207 Member
    5
    Guys, I'm new to HD talking and this is my first post. I need to change out my compensator sprocket and primary chain on an 03 Heritage. Do I need a clutch pulling tool to get this done?
  2. fin_676
    5,789
    153
    288
    The most important tool you will need is the sevice manual
    you will need to pull the clutch but i dont think you need any special tools for it the clutch nut is a reverse thread so you have to turn it the opposite way from normal
    you will need a bi directional torque wrench for getting it back on and to the correct torque
    but its all coverd in the service manual
    both the compensator and clutch nuts are assisted in staying in place by red loctite which may require heat to get it moving
  3. odin2207
    odin2207 Member
    5
    Thanks Brian, when you say heat, do you suggest a torch or heat gun?
  4. fin_676
    5,789
    153
    288
    As my bikes are all evos ive never done a tc but im pretty sure they are pretty much the same in the primary
    i tend to use a torch and get it nice and hoy then then the loctite will part however you may not need the heat
    best to have an assistant to stomp on the rear brake and hold the bike while you swing on a breaker bar to loosen the nut
  5. glyd-n
    glyd-n Junior Member
    406
    +1 I've done a couple of them and it is the same process.
  6. bartos
    bartos Member
    19
    I've done this a few times and find that it is easiest to use a clutch hub puller, in reality you can use any type of puller just be careful not to crack the basket.
    A good breaker bar can break free the compensator nut and the clutch hub nut, I read a tip a while back that you could rollup an old t-shirt to keep the primary chain from moving so that you can loosen the compensator sprocket nut and it worked great for me!
    For the clutch hub, typically will just put a piece of pipe over my ratchet and then put the bike into 4th or 5th gear and then apply the brake and loosen the nut.
    I've never used heat, but I have heard of others that had to in order to free things up.
    And remember, the service manual is your friend. :D
    Good luck, let us know how it goes.
  7. glider
    50
    Don't forget it's the opposite thread too. (left handed)
  8. chester1957
    chester1957 Member
    65
  9. bartos
    bartos Member
    19
  10. TQuentin1
    4,737
    142
    NO IMPACT WRENCH!!
    Use a breaker bar and a cheater if you need one.
    You can make up a simple tool to jam the sprockets with the chain using one of the polymer cutting boards. What you end up with should look something like the pix below. FOLLOW THE MANUAL!!
