compensator gear
Discussion in 'Transmission' started by nascar7613, Jul 22, 2008.
  1. nascar7613
    nascar7613 Active Member
    241
    38
    5
    I have been trying to find out if there is anyone who is making different tooth count compensator gears for 07 and later. I would like to go a couple teeth smaller to get a little more punch on the bottom. If anyone knows of one please reply. Thanks.
    Evolution industries makes one but it is a solid hub and not a compensator hub. I wouldn't change the gearing on the 96, you may be looking for trouble.:s
  3. nascar7613
    241
    38
    5
    Thanks for the reply Glider. My bike is a 110, still asking for trouble? What problem might I create?
  4. glider
    Wellllll....The 110 is slated for a recall for a few things that HD will notify the owners about shortly. It also shares problems with the cranks the same as some 96's do but emphasized more with the addition of more power.
    By removing the compensator and going with a solid pulley like the evolution setup, you are stressing a weak link (crank) even more than before. Crank run out that comes from a poor design has caused replacement in more than one crank in the 96.
  5. Papamte
    Papamte Member
    39
    You might give the folks at BDL a call. I know they make a 24 tooth in the new compensator, but don't know if they make them with over 25 for the twincams. At least you'll retain the softening effect for the crankshaft.
