Coil with points vs coil with electronic
Discussion in 'General Harley Davidson Topic' started by illusionrider, May 30, 2015.
  1. illusionrider
    illusionrider New Member
    3
    I got a bike that had an electronic start and it didn't work. The guy I brought it to changed it over to points. Should he have changed the coil too. Just wondering if it should have a different one for points cause now my coil went out. Not sure what to get
  2. gusotto
    gusotto Junior Member
    604
    38
    13
    Info with year/model would help.
  3. chief08
    chief08 Member
    37
    18
    get rid of points they suck
  4. gusotto
    604
    38
    13
    I'd agree.
    Haven't messed with points for decades!
    No need to.
  5. fin_676
    5,775
    153
    284
    I do not think that it should matter what the trigger system for the coil is the same coil should work with points and electronic triggers
    Points are simple in the way they work and require regular maintenance as the cam follower wears and the points gap closes every time the gap is adjusted the ignition timing needs adjusted to suit
    Power flows through the coil (creating a magnetic field in the coil) through the points to ground when the points open the power flow is stopped which collapses the magnetic field in the coil, the collapsing magnetic field is captured by the coil core and redirected to the spark plugs an creates the spark
    When electronic ignition is used sensors are in place of the points which send a trigger pulse to the ignition module the ignition module cuts the power flow through the coil and so a spark is created
    Things do get a wee bit more complicated than that so the correct coil for the bike should work with either system unless something else has changed
    Heat , vibration and time are not good for a coil and they do die
  6. tourbox
    tourbox Senior Member
    1,885
    168
    There are differences in coils for points versus some electronic ign. systems. A points coil requires a 5 ohm coil. Most electronics are a 3 ohm coil. Now I run a Dyna DS6-1 system on my Shovel which calls for a 5 ohm coil for street but a 3 ohm for racing. I run the 5 ohm
    coil. Other more sophisticated systems like a Crane HI-4 probably call for the 3 ohm coil. New Twin cams are a 0.5 ohm coil, hole different can of Worms.
    tourbox
  7. Jack Klarich
    Even tho points are old tech, I like them for simplicity in replacing and trouble shooting, carry a spare set and condenser and you are good to go
    Tourbox has given you the correct info on coils:s
  8. illusionrider
    3
    Thanks guys and my bike is a 1981 FXS lowrider had electronic I'm wondering if it would make more sence to put an electronic back in. Idk
  9. Jack Klarich
  10. chief08
    chief08 Member
    37
    18
    yes you should you will be much happier. points r history. :s
