Codes
Discussion in 'Engine, Fuel and Exhaust' started by ahern25, Jul 7, 2012.
  1. ahern25
    ahern25 Active Member
    143
    2004 Fatboy EFI model. 23,000 miles.
    Was on a 200 mile ride today, speeds about 65-80 MPH, about 95 degrees out. Almost home when I noticed the bike began to run rough and misfire. Felt like I was not getting enough fuel. Rode it that way the last 30 miles at about 40 MPH cause it would not want to go any faster. Even at such a low speed it kept wanting to die out and coughing as if it had the ebola virus. Finally got home and checked the codes. P-none, S-none, SP-B1004, B1005, T- No RSP. Question is now that I have the codes. Where do I go from here? I know it has to do with the fuel system but not sure where to start. Any help would be nice. Thanks
  2. Bodeen
    4,647
    73
    222
  3. ahern25
    143
    No rain, no tach, fuel gauge was fine and moving every time I pumped gas. It was just hot out. Wondering if maybe the engine was to hot and it went into limp mode? Will try it out today and see what she does.
  4. TQuentin1
    4,737
    142
    Check this out:
    Harley Davidson Community
  5. ahern25
    143
    Primed the fuel pump removed the fuse and tried to start the bike. Just a loud pop but did not kick on. Losing fuel pressure some where. Good place to start. No concerned if the hoses are covered under warranty. If not I might have to do it all myself.
    125 dollars later, back to normal. I had a small hole in my fuel line. Went with Harley OEM parts. Looked them up on JP Cycles and could have saved 50 bucks. Live and learn. Bike is running top notch. Thank you to all who responded.
