Clutch Spring
Discussion in 'Transmission' started by Porter, Mar 18, 2010.
  1. Porter
    Porter Junior Member
    534
    4
    I have a 2007 UC and I am looking into order replacement clutch plates.
    According to the HD site there are 2 "kits":
    37969-03A (metal plates, fiber discs and spring)
    37980-10 (metal plates, fiber discs)
    If I am going to do this work, should I replace the sping or use the old one?
    My gut says replace it given that I would think heat would weaken the spring over time, but then I questioned why they would sell the spring seperately as well as with and without the plate/discs?
    Thanks for any advice.
  2. ultrat
    ultrat Senior Member Contributor
    1,315
    I do not think a primarys heat would cause the temper to go out of the spring...
  3. Hoople
    Hoople Account Removed
    7,198
    34
    According to my chart, both part numbers have same list price of $169.95.
    I can't understand why that would be because it does not say 1 number was substituted?
  4. Porter
    534
    4
    I figured it may be a typo on the website, but Zannotti's lists both part numbers as the same price ($142). I'll try contacting my local dealer and see what they say...
    Thanks for the reply Hoople!
  5. Jack Klarich
    When I do clutch work I dont like problems so I replace all internal parts and release parts as well as springs to ensure proper engauge and dis engaugement, why take chances JMO
  6. Porter
    534
    4
    I agree with you, and given how simple the spring is (in design) I would think that there would not be a problem using a new one. Maybe it is my bad luck, but I have had problems installing something "new" and it was defective from the start. It always makes me think, if it is not broken and works, don't replace it. Then I end up out thinking myself!:p
    This weekend I am replacing the fuel filter and installing my new headers that came in yesterday from JetHot (originals cracked and I welded them). The clutch will be next weekend or later, but I am trying to get all the parts together well in advance.
    Thanks for the advice!
  7. Bud White
    3,270
    replace the spring its cheap if you go with the SE spring be warned its heavy
  8. Porter
    534
    4
    Good to know. Thanks for the info, I don't think I want a heavier spring. I like my comfort and the original one worked fine.
  9. Bud White
    3,270
    you do get used to it .. and you sure know when it hits under power
  10. Porter
    534
    4
    Thanks Bud White!
    Now you got me thinkin....oh so many options....but that is the fun of owning a HD!:D
