clutch release mechanism
Discussion in 'Sportster Models' started by ironhorserdr, Aug 20, 2010.
  1. ironhorserdr
    ironhorserdr Member
    14
    Can someone help me find a picture of how this is suposed to look mounted on the crankcase cover please? I have looked, and looked.. In the shop mannual it only shows for 1970 and earlier..It seems like a spring should be on it somewhere, there was no spring in the kit I bought to replace the old clutch release mechanism..
    it's on page 144 of the clymer 59-85 mannual..
    Edit: page 56 in the Periodic Lubrication maintenance and tune-up section. So NM on that!
    is incase anyone else need to know 71 and later sportster models.
    [​IMG]
  2. fin_676
    5,777
    153
    285
    Im just a wee bit confused as your avatar says your bike is a 92 ironhead as far as im aware ha stopped making ironheads in 1985
    1992 sportster is an evo engine so your engine must be 1985 or erlier if you are buying parts for a 92 sportster then you will have the wrong parts
  3. ironhorserdr
    ironhorserdr Member
    14
    oops lol good eye it's a 82
  4. fin_676
    5,777
    153
    285
    Sorry then i cant help you as my area of knowledge is in the evo range i have never seen an iron head close up
  5. ironhorserdr
    ironhorserdr Member
    14
    got everything back on, no leaks form the crank case. only problem now. the clutch cable is too tight, and the lever wont pull back bleh...
    we have adjusted it,per the shop manual instructions. maybe time for a new clutch cable? it is an old one.
