Clutch Noise
Discussion in 'Touring Models' started by glenalt, May 3, 2010.
  1. glenalt
    glenalt Junior Member
    406
    36
    I came back from a short ride today and after cleaning it up I was pulling it into the garage. After starting I held the clutch in, waiting so it wouldn't clunk as loud, and when I let it out I noticed it sounded like some marbles rolling around inside making a low level rattle. With the bike in neutral and the clutch held in there is no noise but when you let it out there is. Any ideas? It's a Ultra Limited with 400 miles.
  2. 08HOG
    08HOG Account Removed
    27
    I have never heard a noise like that and alot of people I ride with have the 2010 Ultra Limited. I would take it to the dealer and let them mess with it, it is under warranty. JMO.
  3. Jack Klarich
    Back to the dealer, let them fix it on there dime:)
  4. TQuentin1
    4,737
    142
    Absolutely! What they said ^^^^^^^^^^^^^^
    What I would be worried about is the compensator nut backing off.
  5. 08HOG
    27
    I never gave that a thought. I would get back to the dealer ASAP
  6. Hoople
    Hoople Account Removed
    7,198
    34
    Yep I have an idea.... If the bike has only 400 miles on it, they forgot to put oil in the tranny.
    Before I brought the bike back in, I would check all the levels.
    Don't want them just putting in 1 bearing with oil and out the door.
  7. glenalt
    406
    36
    Yep, I planned on taking it in tomorrow and will check fluid levels before I leave. I thought I would run it by here first. It's nice to have a little info before you go in as sometimes the answer is it's normal.
  8. 129South
    129South Member
    21
    My wife's 09 Heritage had a problem very much like yours (same type sound when clutch was in). Her problem was a faulty start swith causing the starter to engage while the bike was running. When the ignition was turned on and the Run switch was on, the bike would start without touching the start switch if the bike was in nuetral. The service writer at the dealership looked at me like I had two heads while I was trying to explain the issue. When he turned the ignition on to get the mileage and codes (if any) the bike started within about 5 seconds, the Vance and Hines Longshots scared him half to death. It's was priceless. Hopefully your problems will be this simple.
  9. glenalt
    406
    36
    Yea, this is with the bike in neutral and the clutch released. It is very low level and I doubt it is the starter. They are pretty loud. Thanks.
  10. larryjmiller
    larryjmiller Junior Member
    448
    Of course, you have to let us know what they found...
