Clutch Issues??
Discussion in 'Touring Models' started by Glideman2007, Jun 2, 2009.
  1. Glideman2007
    Glideman2007 Member
    10
    I have a 2007 street glide with about 9300 miles..i changed the engine oil at 9000 with syn3..at 5000 miles the dealer did the primary and oil and used syn 3 as well...it seems i'm having a little slippage in the clutch. someone told me you cant ajust the clucth only from the cable end at handlebar..(not sure if thats true)..anyway some times it seems to be fine and other times it seems to drag?? my next step is to change the primary oil to the harley formula plus...and redline in the tranny..any suggestions on the clutch issue?
  2. R. Lewis
    2,183
    5
    I would be more concerned with the clutch plates and cable than I would what brand of lube that was in it. You will get different opinions on lubes. Is the scoot still under warranty? How long has this been happening??
  3. Glideman2007
    Glideman2007 Member
    10
    not under warranty...it is recent that its been going on....i've been riding for a long time so i know it's not rider error...it just seems a little sloppy?
  4. Dr. Dolittle
    6,404
    118
    29
    Do you have the Service Manual? It tells you how to adjust the clutch and you're right, it's not just done with the cable and the lever, you have to remove the primary cover.
    Also, most on here would agree that you should do a bit of research and upgrade your fluid choices.
  5. mnultra
    mnultra Active Member
    293
    Also search for the easy clutch adjustment procedure Glider posted.
    It is easy:D
  6. dave_shovel
    dave_shovel Member
    7
    Glideman,
    You mentioned both having slippage and dragging. Both are different and usually don't happen together, unless your clutch plates are bad. On the Older Evos, there was a spring disk between the cluth plates that would go bad and cause both of these symptons.
    In your case, I believe a simple clutch adjustment is going to be fine.
    DS
  7. TQuentin1
    4,737
    142
  8. oiler
    oiler Active Member
    150
    To much oil in the primary can cause clutch drag.
  9. dhorne
    dhorne Active Member
    258
    Plus he fact you said you were using synthetic in the primary , synthetic is slippery and will cause the clutch to slip in time
  10. STEVE07
    4,125
    68
    85
    My bike has 25000 miles on it and has had syn.3 in the primary since new,no slippage.
