Clutch cover help!
Discussion in 'Sportster Models' started by jeepin, Sep 17, 2011.
  1. jeepin
    jeepin Member
    30
    So I've tried a torx 27 on the clutch cover and have twisted off two bits. How the (EDIT) do I get these things off?!?!?!
    Sent from my Droid using Tapatalk
    Please read this...
    [note]
    [/note]
  2. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Once a Torx is ever so lightly spun in the head, It won't come out to save your soul...
    A light duty Knock-off tool is needed to apply even, Quick pressure to get them out..
    ME, I carefully use the right size torx bit and keep it straight and pushing in to apply even pressure and they POP right Loose..
    I've had to do it the old fashioned way once with a chisel and hammer.. others Drill OFF the head and take out with fingers or a needle nosed pliers after cover is removed....
    They can be a Real BUGGER....:naughty
  3. glider
    50
  4. jeepin
    jeepin Member
    30
    When it says, use a drill, I'm guessing it means drill bit? I don't get, please exguse my ignorance
  5. fin_676
    5,788
    153
    287
    What you need to do is remove the head of the screw so that the clutch cover will come of and leave the threads in place once the cover is off all the tension is off the thread and the threaded part of the screw can be easily removed by hand or with a locking pliers
    it is the tension of the screw head against the clutch cover that usually makes these screws difficult to remove use a drill to drill the head off
  6. Jack Klarich
    Very good read here, The captive washers under the bolt heads causes the problems, I use Antisieze here never had a problem :s
    Use a quality drill bit, if you have a left hand bit some times you can spin the broken fastener out:s
  7. jeepin
    jeepin Member
    30
    Check. Got it now, thanks for all the help.
  8. IBA Harley
    IBA Harley Active Member
    139
    I removed ALL the torx head fasteners on my Harley for this very reason. AHHHH... drives me crazy. :)
  9. jeepin
    jeepin Member
    30
    I can't stand torx bits, it still baffles me as to the reason of use.
  10. Jack Klarich
    Easy for the robotics to hold them in place while assembling the cover:s
