Lobo1
Junior Member
I got a couple questions on adjusting the clutch on my 1988 FLHS. The H D service manual says to loosen the cable adjuster, loosen the locknut for the Allen screw that puts pressure on the clutch push rods. I get all that, but it says to put a straight edge across the spring and measure the gap between the spring and clutch hub. Should be 0.00” to 0.010” concave or convex. Mine is totally flat. I rotated the adjuster plate to the “C” hole pattern to put more pressure on the spring and it is still flat. Thinking I am not looking at it just right or maybe I am missing something.
The reason I was checking it is that the clutch lever has 1/16” free play at the ferrul but the clutch doesn’t catch until the lever is let out about 3/4 of the way. I am going to pull the discs and plates out to measure them with a vernier caliper to check for excessive wear unless someone here can give me a little jog in what I may be doing wrong. The clutch doesn’t slip at all, not even fully loaded and pulling a hill. I want to get it to engage when the clutch lever is about 1/4 way from fully pulled in.
Thanks in advance.
Thanks in advance.
