JJDH
i read the tips on here also watched the video, let me explain, when i got my 2010 street glide the clutch lever had alot of slop in it, so i adjusted the cable ajuster close to the oil filter. there is no slipping, the operation feels fine. now since then the lever now has more slop in it, needs adjusted, now here is my confusion, if i do the adjustment inside the primary on the clutch does that take the slop out of the cable? my cable adjuster in the front seems almost maxed out, meaning not much adjustment left, when i let go of the lever it doesnt return all the way to the resting postition, it has now a good 1/2in or more of free slack in the cable. any help appreciated. will the adjutment in the primary be the solution?
