Climbing trouble
Discussion in 'Engine, Fuel and Exhaust' started by ffejski, Jun 24, 2014.
  1. ffejski
    ffejski Member
    7
    I'm Jeff new to the forum, hi to all,
    I have 1995 FLSTN, heads done, S&S super E, V&H exhaust with crossover. I will try to describe my problem and appreciate any help I can get. I have had the bike for ten years. When riding two up and pulling up a hill there is the feeling of a hesitation under 1/4 throttle, like a slight bucking, like I'm tapping the brake. It goes away when applying more throttle. It's not rythmic but more random. I don't hear a misfire, and the bike seems to vibrate a little more than it used to. The primary chain is adjusted correctly, new plugs installed. Could this be a compensator issue and how do I check it? Thanks in advance.
  2. Jack Klarich
    Welcome to The Forum, The older comp sprockets did not pose many problems, have you checked your primary chain tension and belt deflection yet?
  3. rhino 2
    rhino 2 Active Member
    182
    Too high a gear for the speed you're going...???
    You might have to down shift....?
  4. wazzle
    wazzle Member
    98
    In the car world you are describing an intermittent misfire from a bad plug wire.
  5. tourbox
    tourbox Senior Member
    1,902
    173
    Welcome from So. Texas. I agree with rhino 2 because you say 2 up. As far as you extra vibration I would check your motor mounts for tightness. Your top mount could also be broken.
    tourbox
  6. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Does the problem go away if you downshift and maintain steady throttle, but with higher rpm's?
  7. ffejski
    ffejski Member
    7
    No it does not. I'm running approximately 2500-3000 rpm. It happens in all different gears depending on speed
  8. HDDon
    5,562
    133
    236
    You don't say how many miles are on your bike or if you have done a compression test or leak down test. I take it since you say you have had the bike for 10 years this is a new problem. I would make sure the motor is up to snuff and I would also check the clutch plates and steels. Over the years things do wear out and get out of adjustment.
  9. ffejski
    ffejski Member
    7
    I'm going to dive in this week the bike has 56,000 miles on it. I'll post what I find. Thanks to all
  10. r_k_dragon
    r_k_dragon Active Member
    270
    4
    Welcome to the forum from the southwest desert.
