Hello all, new to these forums. Bought a 95 sportster 1200 last year and am having a problem with it now. I went to take it out and when it is in gear and not running I can move it back forth and it makes a clicking noise coming from the transmission area. I removed the primary cover to find the engine sprocket nut sitting in the cover not on, I replaced the nut with a new one and it still has the same problem. When this nut came off Im assuming it messed something else up. Do you guys have any idea on what I should check next? Im thinking I should remove the engine sprocket and clutch assembly and look behind there? Any input would be greatly appreciated. Thanks, Kevin.
