Starting issues
On my bike, I check the fluids and battery and I have a volt gauge on it. The bike crank up good. I let it warm up at about half choke for about three to four minutes, I check the volt gauge was in the first green where the idle was around 900 rpm,s. I took off easy getting it warmed up some more. I rode about 30 miles and as I started to take off and get up to around 40 mph, the bike just stop running. It was no knock or jerking in the motor. I pulled in a safe spot and noticed that the lights were still on and the volt gauge with the switch on was still in range. Check carb, was getting fuel.As I turned it over all it did was spin, not catching. I know bike had new battery,stator and voltage regulator put in last year. Havent got a chance to do any more technical dia on it.
