choking me out
Discussion in 'Engine, Fuel and Exhaust' started by ol' crusty, Oct 11, 2010.
  1. ol' crusty
    ol' crusty New Member
    My brother's 88", carbed, '03 Super Glide wont run without patially pulling the choke out. The carb looks clean and the bike only has a little over 1000 miless on it. Help! I'm clueless.
  2. Jack Klarich
  3. dbmg
    dbmg Guest
    Might try a can of Seafoam through tank.
  4. wb4eje
    wb4eje Member
    34
    18
    Whoa! A '88 is a 22 year old bike with only 1000 miles on it? That bike has been sitting. I agree, try a can of sea foam through it. But, I am thinking that as much as that bike has sat without being ridden, it is time to pull the carb off and disassemble and clean it! Seriously, it may be clean on the outside and inside the venturi, but I bet the inside of the fuel bowl looks like varnish!
    Bob
    Woodstock, GA
    1 person likes this.
  5. harley@16
    harley@16 Junior Member
    483
    5
    not 1988- 88cu in
  6. wb4eje
    wb4eje Member
    34
    18
    I guess I need to read these a little slower!! HA! Having the run with the choke on says something is blocking the fuel. Bad gas, dirty gas, gum, sludge, something. I would still have that carb off there and apart on the bench......
  7. NEWHD74FAN
    8,191
    98
    19
    While likely fuel system obstruction or poor gas picked up, with poor jetting less so....IF the bike was running and set up fine before getting to this degraded state. Could also be carbon/IC deposits sticking the CV Slide or plugging up small passages. A bit of Gumout Carb Spray cleaner strategically aimed in the carb may be a all that is needed. Drain the fuel bowl contents in a clear glass and check for debris.
    Another possibility is a vacuum leak...so do check for little things using WD-40 to spray mating intake surface gaps listening for change in RPM and need for choke/enrichener...just a thought. I am one to troubleshoot down to two reasons to change out something, and use diagnostics rather than just throwing hardware or "shotgunning"...gets too expensive and wasteful that way.
  8. eleft36
    eleft36 Junior Member
    441
    Running only with the "choke" (enrichment) out points to the pilot jet and/or it's passages plugged from popping back through the carburetor. It needs to be taken apart to clean out the hardened carbon properly.
    Al
    :USA
    :CONNECTICUT
  9. Ranger518
    Ranger518 Member
    9
    I have a 97 sportster 1200 with s&s carb and am having the same issue, wont idle or run unless the choke is 1/4 up. Just bought this bike and it did set for months prior to me buying got a lot of ideas from this post.
