Checking for codes
Discussion in 'Engine, Fuel and Exhaust' started by Dferr, Apr 27, 2011.
  1. Dferr
    Dferr Member
    35
    Could installing a TFI cause problems with getting codes? I recently installed a TFI and everything seems to be ok except, I’m getting poor fuel mileage and I recently noticed the check engine light was coming on a few seconds after startup and then go off after 5 or 6 seconds or so. I decided to check for codes and it displayed two. PO261 and PO263. They indicate injector open low EFI. I cleared the codes and restarted and it now has no codes. I’ll have to ride a little more to see if they come back on. I was just wondering if disconnecting the injectors and reconnecting the TFI could possibly cause this.
    50
    Hopefully the key wasn't on when you did the hookup:D
    It shouldn't cause a code unless there is a bad connection.
  3. Dferr
    Dferr Member
    35
    No, the key was not on. But I was getting a little sparking action when connecting the ground wire to the bat. I didn't think that was very good. That means something must be live right? Or is that normal?
  4. Hoople
    Hoople Account Removed
    7,198
    34
    The sparking was not caused by the TFI. Several factory circuits have small drains when the key is off. Plus depending on how long the battery cable was off, filter capacitors in items such as the ECM, Speedo & TSSM will recharge when you first re-connect. Seeing small re-connect sparking is not anything to worry about.
  5. Dferr
    Dferr Member
    35
    Ok thanks, I'll keep an eye on it to see if the codes come back.
