My check engine light and battery light comes on and drains battery. I have replaced the battery 3 times and regulator twice. Taken to the dealer and they have checked everything. Stator readings are 23 volts AC and idles and 60 at fast idles. Regulator reads 14.6 volts DC output. Grounds have all been checked and double checked, Battery has been checked and load tested. (less then a volt drop) Wire from regulator show 14.6 volts at regulator but at battery it is only 12volts or reads battery voltage only. Five HD mechanics have logged a total of 9 hours scratching their heads without solving the problem. Still the battery will not charge, engine light and battery light are on constantly. Continuity test have been run on the stator and shows 00.2 resistances. Continuity test on wiring from regulator to battery show no resistance.
Does anyone have any ideas why my system is not charging.
This all started after I had jumped on it and wound it up and then got off of it because a car pulled out in front of me. So high RPM acceleration with high RPM deceleration. Don't know if that helps.
