Changing out the Screaming Eagle race tuner to the TFI
Discussion in 'Softail Models' started by elkhunter149, Aug 22, 2009.
  1. elkhunter149
    elkhunter149 Account Removed
    134
    Anybody know what I would have to do to change my existing 08 roadking HD race tuner to the TFI plug and play unit? I get alot of popping on decelartion, and back fire. Take to the Stealiership or inhouse?:D
    You would need the stock map in the ECM for the bike then just change it. Why do it thou being you have the SERT on it now other than the backfiring. A good tuner can richen the decel settings and eliminate it.
  3. elkhunter149
    134
    Glider thanks for the reply, U seem to know what U are talking about with the TFI. Are U saying I can just instal the TFI plug and play into the existing ecm with the HD race turner?
    Ken
  4. Bud White
    3,270
    you could add it on but what hes saying is why when you have the SERT why not have a good tuner tune it right
  5. elkhunter149
    134
    I asked my local stealership about checking my race turner after six months of use and they said I didn't need to do that. I had read that they do need to be retuned. Thanks for the reminding. My roadking gets a good work out with the sidecar and our mountains.
  6. glider
    If you had it tuned properly, there really shouldn't be a need to retune it. What I said above is to remove the SERT map, reinstall the stock map and then install a TFI if you wanted but again,have it tuned properly by a competent tuner to eliminate the decel popping.
  7. jody7734
    jody7734 Active Member
    221
    Remember too, you wont be able to sell the SERT as it cant be moved to different bike.
  8. 03classic
    03classic Junior Member
    424
    Were there any mods done after the SERT install? The canned map should have taken most of the decel pop out of the bike.A custom map should fix your problems.
  9. elkhunter149
    134
    I had the reinhert true duals, screming eagle high flow filter and the race tuner all put on when new at the same time.
