Chain Tensioner Pic
Discussion in 'Touring Models' started by hotrodjohn, Jan 7, 2011.
  1. hotrodjohn
    hotrodjohn Active Member
    183
    I pulled off the cover today to check my tensioners. Here is what I saw. The front looks ok in my opinion and the back looks like the font from what I can see in a dental mirror.
  2. rkrdr2
    rkrdr2 Active Member
    163
    They look real good to me..a lot of life left in them...What's the mileage?...I ride an '04 and changed them out @ 27k...mine were worn more than that but no where near the critical stage...keep changing that oil!..early and often!
  3. hotrodjohn
    183
    26,000 miles I bought the bike at 20,000 and I dont know if they have ever been changed??
  4. TQuentin1
    4,737
    142
    They look VERY good for 26Kmiles. You might get your HD Dealership to run the VIN and see if they can find any maintenance history on the bike.
  5. billnapabill
    billnapabill Active Member
    316
    What kinda motor oil you running? They look good for 26k. I had to change mine out at 24k on my "02". The rear one was completely shot. I was running HD SE3. I change to Red Line, looked at em again at 78k and they still looked brand new.
  6. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Man,,,, 78k(52k) and looking new,,,, I'd like to think the Redline Helped over SIN3 and cam chains SMOOOOOOOOth Off Sharp edges to be the other helper..
  7. Jack Klarich
    HMMMM, can oil make this much difference here?
  8. NEWHD74FAN
    8,191
    98
    19
    Not bad wear considering year and mileage...and as others have stated, results may be even better if heavier lubrication were used. If you have it apart, it may be easy to replace them now or if parts are not in stock at least you will be ready to replace the shoes when you have it apart again in the future.
  9. blitzking
    blitzking Member
    14
    It looks like your good for now.
  10. Dak47
    Dak47 Member
    19
    I started with checking shoes @ 50,000KM/30,000M, didn't like what I saw, checked crank runout, so-so, ended up yarding the motor and putting my 103 stroker kit in.... what a slippery slope :D, think I caught the shoes just in time. Amsoil, changed early and often, though I can at times be an idiot with the throttle...
    Dirk
    [​IMG]
    [​IMG]
    [​IMG]
