J
Jack Klarich
Guest
Under NO circumstances should you hone an Aluminum master cylinder or use any abrasive on the pistons. These have an anodized finish on them and the scratching will ruin the finish and cause leaks. Best to clean all parts in alcohol and flush with hot soapy water, air dry and use quality Assembly fluid with new seals for reassembly.
