carb or fuel problems
Discussion in 'Engine, Fuel and Exhaust' started by hdog, Dec 3, 2012.
  1. hdog
    hdog New Member
    i have a 2000 electraglide classic,it coughs on low end take off in every gear like it has bad gas,i have drained the gas,changed the air filter,fuel filter,o rings on intake manifold,spark plugs,cleaned out pin holes on primary jet but not secondary jet because i couldnt get it out,checked vacumn line and fuel line,any sugesstions?
  2. Slo-Ryd
    Slo-Ryd Junior Member Contributor
    527
    23
    Did you double check your intake seal work? I've had nagging intake leaks in the past that took 2 or 3 try's to finally get them to seat and seal properly. Use WD while running to spray around the seals to verify the leak isn't still there. Also check the diaphram for the slide by removing the top cover of the carb for a pinched or torn diaphram. A torn diaphram will exhibit driveability issues like you mention in all gears. Intake leaks will usually cough when starting off from a dead stop. Keep us posted if you find the issue.
  3. Bodeen
    4,643
    73
    221
    Great advice here. Also check the spray coming from the accelerator pump and make sure that it is spraying straight down the throat of the carb. You can use a pair of needle nose to adjust the spray left or right as needed. Also replace the accelerator pump diaphragm.
  4. Jack Klarich
  5. HDDon
    5,543
    133
    229
    All good advice. Along with checking the accelerator nozzel spraying stright down the bore I would be looking at the accerator pump diaphram. With the E10 gas here in Fl I have replaced mine a couple of times in 3 yrs.
  6. TQuentin1
    4,737
    142
    You may also need to check your main slide diaphram. This is a bit of a chore, but if there is a crack or pinhole in it, you will never adjust it out.
    I am assuming you have NOT drilled the vacuum port on the slide to 1/8", right. If you have, low end problems can be a result.
  7. lordharold
    lordharold Active Member
    191
    Probably need to check your other jet a small flat screw driver should work.
  8. 01 rk
    01 rk Active Member
    318
    My sons 2001 flh had the same symptoms, found the gas cap was not sealing tightly.
