Can insturment lights be brighter?
Discussion in 'Touring Models' started by lwilliams, Oct 12, 2010.
  1. lwilliams
    lwilliams Member
    I am wondering if there is a way to make the instruments panel lighting brighter on on 2010 Ultra? I would like the lighting to be a little bit brighter than it is......not a lot. It's just not bright enough as it is.
  2. gusotto
    gusotto Junior Member
    604
    38
    13
    You could change the bulbs but can't tell you which bulbs.
    I don't want the lights too bright at night because it will interfer with my night vision.
  3. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Until you posted this question, I thought the "display" function on the radio also controlled the instrument lights. I went to the garage and checked, and it only changes the radio display.:( You could pull the little orange covers off of the 2" gauges (speedo and tach lights are inacessable led's). That would make them a little brighter, but also whiter which would affect your night vision. I replaced all 4 of my 2" inst. bulbs with red ones (auto supply). It barely made a difference in the appearance or brightness. So I guess the easy answer is no.
  4. lwilliams
    lwilliams Member
    So far, it likes like NO is the most popular answer.:(
